I've got the Aux in outlet in my console, and was wondering what you all use for the cable to connect Ipod's with?
Is the only option using a cord w/ 3.5mm plugs on either end and plugging it into the headphone outlet on the Ipod, or are there better options out there? Specifically, I was wondering if there was a cable that would plug into the bottom outlet on the Ipod (where you'd normally plug in the Ipod cable to charge up the ipod or connect it via USB to a computer) and would have a 3.5mm plug on the other end to plug into the Aux in outlet--that way allowing the music to be transmitted while also charging up the Ipod?
What do you all use and/or recommend?
Thanks!
Thanks!
